2020 intake screen
David
11-07-2003 07:31:33
In my 2020 shop manual, it does not specify if I need to drain the hydraulic fluid in order to remove the intake screen for cleaning. The answer is???
thanks
Brokenwrench
11-07-2003 07:57:21
 Re: 2020 intake screen in reply to David, 11-07-2003 07:31:33
Yes the fluid has to be drained. The screen is at the bottom of the reservoir.
David
11-07-2003 08:04:13
 Re: Re: 2020 intake screen in reply to Brokenwrench, 11-07-2003 07:57:21
I wasn't sure, as it also says I don't need to drain the system in order to change the filter.
thanks
John
11-07-2003 09:42:22
 Re: Re: Re: 2020 intake screen in reply to David, 11-07-2003 08:04:13
You dont need to drain to change the filter. But you do have to drain to change the screen in the reservior.
