Adj hubs
ed read
04-22-2000 10:22:17
does anyone know a easy way to un sieze a adj axel on a 520 i tried the process described in the owners man. on adjusting the hub. the 2 cone wedges must be rusted.also thanks Gman and Chuck on my steering lock up it was the worm gear. i had to remove a few shims. that tightened things up.thanks again ed
20/30/40
04-23-2000 09:56:45
 Re: adj hubs in reply to ed read, 04-22-2000 10:22:17
It's not really recommended but with the tractor on the ground hit the end of the axle with a 12-16 lb sledge several times---this tend to "drive" the axle back through the tapered sleeves.I've had to melt some of them with the "blue wrench".
Charlie
04-22-2000 19:35:22
Our 3020 has been rusted tight for a long time(15 years) We were told to loosen it up and drive it, but that didn't work. Last thing we tried was an air hammer.
