Internal engone cleaning with kerosene?
Dennis
11-07-2003 07:03:15
My owner's manual (JD Model B) says to periodically clean internal engine sludge with a gallon of kerosene. Says to "run the engine for a few seconds". I'm wondering if any cleaning takes place w/o the engine running, i.e. turning it over by hand. I am draining out (or trying at least) probably decade old oil from an engine that is too cold to start w/o first changing the oil and I don't have a heated shop and it is very cold outside. Thoughts?
Loren
11-08-2003 03:25:23
 Re: Internal engone cleaning with kerosene? in reply to Dennis, 11-07-2003 07:03:15
My J-D manual says the same thing for my 1010. However, I remember from my teenage years when my cousin used to take that advice seriously with his cars. He went through about four or five engines on three different cars while I was still getting along fine with mine by just doing regular oil changes. Personally, I wouldn't do the kerosene.
Henry J
11-07-2003 15:34:08
Dennis
I would not let the sludge and the amount of it inside the engine bother me a bit. It ran for 4 decades didn't it. I just switch to good ole modern oil (detergent), watch when it gets dirt and change it and the filter. It will clean that engine up inside the natural way.
Now you will hear all the woes about clogging oil passages. Maybe I have been luck for over a half a century and a decade plus. It has worked on ole cars, trucks, and my JD.
You gotta do what makes you comfortable.
DiggerLarry
11-07-2003 09:36:54
I've used the kerosene cleaning recommended by JD. I would think you would get some of the sludge out without running but would not clean the oil passages, etc. The crank also slings that kero around in there to help clean. I'm sure it would not hurt to just let it drain through and after you get it running maybe next oil change, you can repeat the kerosene cleaning and run it a few seconds.
