3pt Hydraulic problems on 430S
sammy
04-21-2000 20:14:29
I have a 430S with dual touchomatic. The 3pt arms will not lift. There are no leaks. Oil level is full. After running a short time oil appears to be real bubbly looking and with longer running if will start foaming out. What do I check for next? Is there a valve stuck somewhere? Is there any test I could run? I have replaced the seals on the inlet line. Thanks for any info?
