Fuel gauge + to
ground ???
PAUL
04-21-2000 20:12:27
I have a 3010D that has been converted to 12v neg ground I need a fuel gauge that is compadable with this system the one I have is for pos ground and won't work one this tractor. I was wondering about a gauge for alate model 4020? thanks for any infor mation PAUL
twopop
04-22-2000 09:19:22
 Re: fuel gauge + to - ground ??? in reply to PAUL, 04-21-2000 20:12:27
I would certainly think a gauge from a late model 4020 or 3020 would fit.however,even tho this will be left open to dispute,I believe the gauge doesnt care whether it is + or - ground. more often it is the sending unit that is defective.
PAUL
04-22-2000 18:26:43
 Re: Re: fuel gauge + to - ground ??? in reply to twopop, 04-22-2000 09:19:22
TWOPOP my sender was bad so was the gauge in the dash the directions that came with the gauge said pos ground only I hooked it up using jumper wires before I installed it in the dash itwould work fine pos ground but the hand on gauge would go to full and stay hooked up neg ground My parts guy at deere knew the ohms of my sender so he might be able match up a gauge thanks PAUL
