Checking compression
matt clark
04-20-2000 18:32:12
I have a 1940 A that was dynoed last year at 42hp,but when i check the compression it shows 60psi onthe left and 50 on the right this seems low whats going on?also how much variance should there be in psi,and still be with in tolerance?
clooney
04-21-2000 03:56:15
 Re: checking compression in reply to matt clark, 04-20-2000 18:32:12
Matt, if your (A) is an all-fuel the compression should be about 70-75lbs. Make sure you check the compression with the engine hot & the carb wide open. Also make sure the air cleaner isn't plugged. The horse power sounds ok with it running. If it runs & pulls good it probably isn't worth messing with it.
