3 Point Hitch questions
jess
04-18-2000 12:09:09
can anybody explain the center/top link operation it has an adjustable pin and a metal gauge for maybe pull load? does the roll-a-matic sticker have anything to do with this. Just bought my first JD a 620
L.C.
04-18-2000 15:18:19
 Re: 3 Point Hitch questions in reply to jess, 04-18-2000 12:09:09
Roll-A-Matic is a type of narrow front end in which the spindles are geared to each other so when one wheel rises, the other one is forced down. It's supposed to aid in steering and ride.
Be careful with a narrow front end tractor on hills: they are more prone to a roll-over than a wide front tractor.
Congrats on your first JD.
LEE
04-18-2000 12:51:12
JESS,WHEN YOU ARE LOADING THE HITCH,THE POINTER ON THE ARM SHOULD BE ON THE CENTER MARK ON THE HYDRAULIC CONTROL VALVE.THERE ARE THREE HOLES IN THE CASTING WHICH CONTROL THE LOAD CONTROL.WHEN YOU RUN A PLOW OR WHAT EAVER THIS SYSTEM WILL SENSE THE LOAD THE PLOW PUTS ON THE TRACTOR AND RAISE THE PLOW UP SOME UNDER HEAVY LOAD AND THEN LOWER IT AGAIN WHEN THE LOAD BECOMES LESS.THE THREE POSITIONS CHANGE THE SENSIVEITY OF THE SYSTEM
jess
04-18-2000 18:47:38
 Re: Re: 3 Point Hitch questions in reply to LEE, 04-18-2000 12:51:12
just wondering what is the maximum load on this system
LEE
04-25-2000 10:39:44
 Re: Re: Re: 3 Point Hitch questions in reply to jess, 04-18-2000 18:47:38
JESS,I DON'T KNOW WHAT LOAD YOU ARE REFERING TO BUT THYE LOAD IT CAN LIFT IS LIMITED BY THE WEIGHT YOU HAVE ON THE FRONT AND AFTER THAT THERE IS A PRESSURE RELIEF VALVE IN THE SYSTEM THAT WILL KEEP PEOPLE FROM OVERLOADING IT.AS FAR AS PULL LOAD,ONE HAS TO USE GOOD SENSE TO NOT OVERLOADTHE ENGINE AND TRANSMISSION.
zane
05-25-2000 17:31:26
 Re: Re: Re: Re: 3 Point Hitch questions in reply to LEE, 04-25-2000 10:39:44
Normally the lift(ing)load is limited by a relief valve in the hydraulic system.
