Head torque on a 28 d
mike
04-18-2000 06:34:33
could someone tell me what the torque spec is for the head bolts. also what is the valve lash spec thanks mike
Bob
04-18-2000 20:03:30
 Re: head torque on a 28 d in reply to mike , 04-18-2000 06:34:33
Mike the head bolts are 208 foot pounds, work from center out and the tappets are .030 Hot or 0 out the clearance and then back off 1/2 turn. Set flywheel at just before LH exhaust valve opens and you can adjust all 4 valves at the same time. Mike might want ot check camshaft timing at this time too. Bob
mike
04-19-2000 06:15:19
 Re: Re: head torque on a 28 d in reply to Bob, 04-18-2000 20:03:30
thanks for the info. i only had the head off for a sticking valve,so cam timing should be ok. however it would be a good time to check just to be sure.
