3020 Questions
Bob Jones
04-16-2000 20:54:39
Just picked up a 3020-Diesel Sat, owner says it started to make engine noise and they shut it down and parked it, yeah sure, run it till it stopped on its own. Crankshaft is broken into behind #2 rod and Cam gear is broke off camshaft. Belive it or not pistons and vavles are good, Are 3020's noted for breaking cranks?? Don't have a clue how they could have broken the crank, anyone with ideas, besides I should of stayed with 2 cyl's.
Question: anyone have a short block they want to sell?? engine ser# 13E79148- Block Casting #R32020R
Really think this could be a good tractor has wide front,3 point, duel outlets, PS trans, diff lock and front and rear PTO.
Any kind of info will be greatly appreciated.
Serial num is a strange one compared to the listings-SNT113P079092R. nothing on the tag states this is a 3020, only side panels have 3020 decals. this is a brass tag too, has some yellow under green in places. Bob
Wi-Red
04-18-2000 01:17:35
 Re: 3020 Questions in reply to Bob Jones, 04-16-2000 20:54:39
My son is in about the same boat as you except with a 3010. After market cranks are about $800 to $1000, then add line bore, bearings, gaskets, ect.adds up in a hurry. I found a 3300D combine that can be bought right, trying to find out if it is the same block or will fit, any ideas?
ronm
04-18-2000 07:29:09
 Re: Re: 3020 Questions in reply to Wi-Red, 04-18-2000 01:17:35
3300 prob. has either a 219 or 329 engine. 3010/3020 engine was never used on a combine, to my knowledge.
ronm
04-17-2000 21:02:41
Without knowing how much you paid for it, it's hard to say, but it's worth fixing, for sure. Used cranks are nonexistent, but there's new aftermarket ones available at WAY less than JD wants. Short blocks are hard to come by, simply because they have to have a crank in them. The 3020 was one of the best, they don't make anything that truly replaces them. By the serial #, it appears to be a PowerShift, which is another plus.
Jim
04-17-2000 11:29:41
Its very common for 3010 an 3020 diesel's to break cranks .One of the major reasons that they break crank is the linebore in the block is bad.
Red Man
04-17-2000 06:29:35
Check the balancer box, something in it could have gone out and contributed to the breaking of the crank.
Nate
04-17-2000 16:44:16
 Re: Re: 3020 Questions in reply to Red Man, 04-17-2000 06:29:35
Your serial number states it's a 3020 the 113 in it tells the story.
Rusty Johnson
01-01-2001 19:32:51
 Re: Re: Re: 3020 Questions in reply to Nate, 04-17-2000 16:44:16
Is a 1972 3020 a 12 or 24 volt system,or both?
