JD 630 weights
Gator
04-16-2000 20:02:57
I have aquired a 3X14 3point trip bottom plow and am curious as to the amount of weights to add to the front end to correctly balance the unit.
Gator
04-19-2000 19:28:15
 Re: JD 630 weights in reply to Gator, 04-16-2000 20:02:57
My tractor is a row crop and I have plenty of D/K 100# weights. I think a set of JD front weights would look a bit better at our 2 cyl club field days but the D/Ks are a lot cheaper. Am still looking for "original" or even reproduced front and/or rear weights. Thanks for the info, gotta putt,will check back later.
LEE
04-18-2000 10:43:48
I PLOW WITH MY 630 AMD A F125 3X16 WITH JD SIDE WEIGHTS AND ONE FRONT.IT GETS A LITTLE LITE ON HILLS ON A HARD PULL BUT WORKS GOOD.THIS A ROW CROP.I THINK THE WEIGHTS ARE ABOUT 420 LBS.
Curt
04-17-2000 13:42:02
It depends on whether you have a tricycle or wide front. The square tube wide front is 300 lbs. heavier than the tricycle to start off with. On our 630 with an F125 3X16 and wide front we carry about 500 lbs. on the front but we have a fair amount of hills here in eastern Pa.. We have a homemade weight rack and we use IH suitcase weights from our modified tractor. Don't worry they are painted black and look pretty good on the 630 and are easy to handle and cheaper to buy than original JD front bolt on weights.
