DLTX Carb (how do I remove the drill plugs)
jonathan
04-13-2000 20:56:45
I am looking for some pointers on removing the plugs in the idle circuit passages on a DLTX duplex carb on a 720 to clean out the passages. Do I only need to remove the two plugs at the intake end of the carb and run a drill trough those plugs as well as up through the idle screw holes? Do I get to the other two small holes behind the throttle blade from the top? What about the air passages from the choke side of the venturi?
Thanks
Jonathan
