3010 gas burner w/carb problem
mike in tn
04-12-2000 10:53:50
i have a 3010 that was introduced as a lp burner. it was converted to gas, the carb on it doesn't look like the one in shop manual therefore i assume someone rigged thisto work. actually it works well except for idling down to low r.p.m..at low idle it will die unless you pull out choke. this carb only has one adj. screw which is located on top ,i was told this was air adj. any advise on adjusting so i can idle while parked without using choke. i must again tell you that under a load it performs very well.
clooney
04-12-2000 13:57:41
 Re: 3010 gas burner w/carb problem in reply to mike in tn, 04-12-2000 10:53:50
Mike, any idea what brand the carb. is? Also are there any names or numbers on it?
Greg H.
04-13-2000 10:30:49
 Re: Re: 3010 gas burner w/carb problem in reply to clooney, 04-12-2000 13:57:41
It sounds like you might have a Zenith Carb on that tractor, but I can't be sure without lookig at it. If it is a Zenith it sounds like your idle screw is out of adjustment, so while it's shut down take and see how many complete turns it takes to to tighten the one adjustment screw on top of the carb. After doing that turn it out 1 3/4 revolutions and start up the tractor. you might have not had this screw in proper adjustment. The idle screw should be set at 1 3/4 turns out, but sometimes it takes alittle more. My Zenith Carb is set at 2 1/4 turns out to make it idle correctly. Hope you get it worked out Greg H.
