Deere D CLutch Question
FFA boy
11-06-2003 10:26:49
Help My D seems to be stuck in gear but the engine still turns over and the rearend won't move. Could this be a clutch problem?
Glen in TX
11-06-2003 14:16:57
 Re: Deere D CLutch Question in reply to FFA boy, 11-06-2003 10:26:49
Could be. Does the clutch lever snap the clutch in and out at all? Will the clutch pulley turn by hand with clutch snapped out or back. Take pulley cover off to see what it looks like inside. May just need to be pulled off and cleaned out. The floating discs could be stuck or broke. If not the clutch check the shifter as may be stuck in gear or between gears. If you had the shift quadrant casting off and someone messed with it could be stuck between gears. You will have to pull the trans. cover off to check that.
