520 steering lock up
ed read
04-09-2000 16:04:18
can anyone tell me what could be causing my 520 steering to lock. when it does it i have to give it a quick gerk and it comes out of it for awile.itseems to happen after being worked hard.it has a factory WFE and power steering thanks ed
Gman
04-10-2000 17:05:17
 Re: 520 steering lock up in reply to ed read, 04-09-2000 16:04:18
Ed Read is it power steering or manuel,if it's power steering,there's a little valve on top of pedesral,if the spring breakes it will cause you similiar problems,and this dude is hard to find. Gman
Chuck
04-10-2000 04:51:54
have had this problem several times. The worm gear is worn and so is the drive gear. Also clearance between the two gears might be off. The best fix is to take the complete worm assembly off. Then loosen the pedistal bolts, also the top gear raise it up and rotate the gear 180 degrees. Will be on new surface then, then adjust the worm assy with new shim gaskets etc. What is happening, the gears are a little galded and they are binding.
