Air in fuel filter
Rick B
04-08-2000 20:52:34
My 310b has a square glass filter that is full of air except about a 1/2 inch or so is this normal the book said to bleed it out with the lever on the pump threw the top plug ,I moved the cam out of the way and it is pumping but it looks like it is just going in and out, is there a check ball in there or something? the machine runs but the air in the filter does not look right. thanks for any help.
Jonathan
04-09-2000 06:34:16
 Re: Air in fuel filter in reply to Rick B, 04-08-2000 20:52:34
It is normal for that to look that way....The only "check valve" is in the transfer pump itself....If , when the engine is running....and there are air bubbles floating up from the bottom of the filter , then that would be a sign of a loose fitting on the suction side of the transfer pump and/or a clogged suction screen in the bottom of the fuel tank...
Rick B
04-09-2000 09:29:07
 Re: Re: Air in fuel filter in reply to Jonathan, 04-09-2000 06:34:16
Thanks Jonathan, this had me worried a little but i guess it will be ok.Thanks again Rick.
