JD MODEL B TRANSMISSION LOCKED
Joe Calzadilla
04-08-2000 19:38:43
CAN ANYONE PLEASE HELP? I LOADED THIS 1948 MODEL B ON A TRAILER IN REVERSE, WHEN IT CAME TIME TO UNLOAD THE TRACTOR THE SHIFTER PULLED OUT. NOTHING IS BROKE BUT THE LOCK RING ON THE SHIFTER IS WORN AT ANY RATE THE SHIFTING FORKS ARE OUT OF ALIGNMENT AND CAN'T GET THEM TO BUDGE EVIDENTLY I'VE GOT GEARS IN THE WRONG SPOTS. MIGHT ANYONE HAVE A REMEDY OR SUGGESTION! THANKS
k hansen
04-08-2000 19:51:33
 Re: JD MODEL B TRANSMISSION LOCKED in reply to Joe Calzadilla, 04-08-2000 19:38:43
Take the cover off and push everything into neutral. You may need to rock the tractor a little or rock the flywheel to get the torque off the gears. Your JD dealer should have a new ring.
J.Calzadilla
04-19-2000 13:48:43
 Re: Re: JD MODEL B TRANSMISSION LOCKED in reply to k hansen, 04-08-2000 19:51:33
Transmission still stuck,Have tried rocking tractor,also lifted rear off ground, wheels do turn in opposite directions.With clutch engaged the flywheel will turn, with it disengaged it won't turn.Have tried getting shift forks to go to neutral, nothing will budge except second fork from top it is free to move. Still needing HELP!
