830 pony or electric start
GHH
10-13-2003 10:38:32
I'm very interested in purchasing a 830 standard but would like to know which would be better, an electric start or a pony start.It seems that electric start 830s are more expensive to purchase but are they easier to maintain? Any advice would be appreciated. Thanks!
Clooney
10-14-2003 03:38:26
 Re: 830 pony or electric start in reply to GHH, 10-13-2003 10:38:32
GHH, having owned both starting types in the 720D & 730D & a pony start 820D [never owned an 830D electric though]�I would say it depends on what you want to do with the tractor. ~If you want to start it once or twice a day & use it most of the day then the pony start will be just fine. If you want to use it as a yard tractor or play with it & move it many times a day then the electric has it's advantages. ~The pony will start much better in the below 20� range & if you want to use the tractor in the below 10� days & don't have a place to plug in a block heater the pony is the only way to go. ~The maintenance on either can be a pain depending of how you treat it & take care of it.
~I find I use the pony starts for longer chores & tend to grab a quick starting gas tractor for short jobs & quick chores.
~One thing I have found on the 720D is there is MUCH more room on the drivers platform with the pony start due to the smaller single battery box. SO, if I spend a lot of time on the tractor the pony start offers more squirming room.
~This is just my personal opinion�I like the sound & charm of a good operating starting engine [pony] & would never be without at least one. I do like the convenience of an electric start though & if the tractor was used many times daily for short jobs it would probably be an electric start�
MIKE HANLEY
10-13-2003 22:28:15
As the stoy goes,,, when the 24 V systems came out for the 720 730 830 (I don't think they were offered on the 820's as there was a change in the late 720's and the 730's and the late one was the one offered in the 830.),,, the pony motots were sold mainly in the cold areas and the electric starters were sold in the the south. We are in Wisconsin and have two 730D's converted to 12 V and have no major problems starting in the winter and they sit in the cold. We use tank heaters though. In this day and ago I would go for the electric as the pony will cost big bucks if it needs major work. The late style 24 Volt starter can be converted to 12 V Nev ground for about $300.
jimbo
10-13-2003 19:05:48
Did not know you could get an 830 with electric start????? Was it an option?
F-I-T
10-13-2003 19:32:34
 Re: Re: 830 pony or electric start in reply to jimbo, 10-13-2003 19:05:48
Yup. Starting with the Black Dashes, the 720/820 diesels could be bought with factory 24v electric start.
Frank
Brandon
10-14-2003 16:27:34
 Re: Re: Re: 830 pony or electric start in reply to F-I-T, 10-13-2003 19:32:34
Sorry Frank,
The 820 did not get the option of electric start. Came close to being added to the options list, but didn't happen till the 830.
Brandon
My Industrial John Deere website
My JD model 80 website
The LaGrange Engine Club
F-I-T
10-14-2003 20:00:01
 Re: Re: Re: Re: 830 pony or electric start in reply to Brandon, 10-14-2003 16:27:34
Well, Brandon you got me!
I thought it was true, but should have checked the parts book. It show it right there, 8300001 and up.
