Now What???
Big Dummy
04-07-2000 17:53:46
Been out of town all week. I arrive home to discover that the starter, and one wire alt. for my 48 G are back from the rebuild shop, and 3 new white face guages have also arrived. I head to the shop as soon as I am able. I fab a bracket to hold the alt., and install the starter. The carb and mag are at Robert's Carb. Wanting to see how the starter works, I engage it. Here is where I errored. I THINK I had a small rag in the intake of the manifold and it is no longer there. I ran a wire down the intake and can not feel a thing. The valve cover is cast iron. Should I pull it? If so do I need a special gasket? Where do I go from here? Good news is that the starter works great, as does the oil pump. With no guage hooked up it shoots oil all over the shop!!!
Chances R
04-08-2000 10:13:40
 Re: Now What??? in reply to Big Dummy, 04-07-2000 17:53:46
Im not really proud of this but if i remember right we had a styled A that we rebuilt the carb on and some how the rag got sucked up in it also. For some reason we forgot about the rag and a couple months later when we were putting the carb back and started the tractor and noticed it wasnt running all that well. We then noticed chunks of the rag coming out of the exhaust stack. The tractor started to run better and has ran great since. We use this tractor as are small loader tractor all most every day now.
Pappy
04-08-2000 00:09:28
BEEN THERE--DONE THAT--HAVE THE SCARS TO PROVE IT!
The person who owned my "A" did the same thing. Only he did not tell me. The tractor was all put back together when I bought it. I tried to start it, it started on one cylinder, then died. I removed the plugs. I noticed a trail of smoke coming from the exhaust. This is what gave me the clue to look for a rag. Red Grease Rag was sucked into both intake valves. Needless to say, the compression test was not good. Try fishing it out from the manifold side, if not, go through the spark plug holes. If you can hook the rag through the manifold or a spark plug hole, rotate the engine while you pull on the rag. The valve just might let it go free and you can pull it out.
G Taylor
04-07-2000 22:40:43
Rent,beg or borrow a bore scope. It will let you check in every place possible without disasembly. Works good as well for purchasing tractors of questionable repair. Owner usualy suddenly rembers hearing a funny sound and will lower the price when you ask to do a visual inspection and oil analsis.
Leger
04-07-2000 21:47:26
Remove carb.- pour a little gas down the intake and burn the rag out!
John T
04-07-2000 20:08:51
Gee, Im glad Im not the only one who has done stuff like that. Well, if the rag did indeed get sucked down in the intake manifold and you cant fish it out, then its hopefully inside the manifold yet, whereby you would have to pull the manifold, not the valve cover to remove it. If you have to pull the manifold you will need a new manifold gasket and I always suggest having it plained to make a nice clean smooth flat surface where it mates with the head. If it got sucked in, it can likely hang and stick maybe partially in the intake valve area and Im not sure what may happen, but it would prevent the intake valve from closing or heck, maybe if the tractor will partially run it will get chewed and/or burnt up???? Its somewhere between the intake manifold opening and the intake valve etc. and not under the valve covers where the rocker arms and valve springs and rocker shaft is unless that tractor is magic. Ol John T in Indiana
