clooney
04-08-2000 05:35:17
Re: 70 gas clutch problems in reply to Jack, 04-06-2000 18:49:08
Jack, some movement of the clutch pulley (in & out) is normal. If the crank end play is correct the movment with the clutch dis-engeged will be determined by the clutch adjustment ( space between the disks), there should be (no) pulley lateral movement with the clutch engaged. So lets look at this problem from the beginning. Is the clutch driving disk (splined disk) tight on the crank splines? If it's loose it will have to be repaired. Are all (3) "dog toggles" installed? If so are they worn? They tend to wear with lots of use. Are the (3) springs installed between the "adjusting plate" & the "pulley"? Lets start the re-assmbly, start by installing the pulley. When installing the pulley make sure the "brass" clutch collar is installed in the GROOVE on the operating sleeve (its kind of tricky), then push the pulley all the way in towards the tractor, next install the inner facing with the rounded edge towards the pulley, next install the splined driving disk (with the external splines facing out)note: make sure it is not loose when installed "when the big bolt is tightened it should become very tight on the crank", then install the two sided driving disk (the one with the 3 ears) over the the 3 pins,then install the sliding drive disk ( the non-lined one with the internal splines),then install the other two sided driving disk ( the one with 3 ears, then install the other sliding disk ( with internal splines), then install the outer facing, next install the adjusting plate (make sure the 3 release springs are in place between the plate & the pulley, now install the 3 nuts on the operating bolts, next engage the clutch then tighten the nuts untill they are all equally tight (tighten them enough to tell if they are all the same torque, I use a torque wrench), now back the off each nut one flat at a time untill the clutch engages & dis-engages correctly. Note: install the (2) facing disks over the drive pins not the operating bolts, but it will work either way.
