2510 Questions
Newby
11-05-2003 21:16:30
A friend of mine needed money and I needed a tractor. I bought a clean, always "garaged" 2510 gas, narrow front end from him for 4,000. That was what he needed to survive and he is a good friend so I really didn't care if I paid to much.
After a bit of research it seems I did all right. I got a JD45 Sickle mower with it and a disc.
The tires are virtually new. It could use a seat cover, but eerything else seems fine.
My questions...
1) Is this a decent tractor? My experence is mostly with Ford 2-8N's and I don't have much of that.
2) Did I pay to much?
3) Will it handle a 6' bush hog?
4) What loader will work on it?
5) Where can I get an owners manual? This has a differnt type of trans than I am used to using.
mcarroll
06-12-2004 06:25:57
 Re: 2510 Questions in reply to Newby, 11-05-2003 21:16:30
Does anyone know the weight (ballpark) of a gas 2510?
Brian
11-07-2003 09:15:47
My dad has a 2510 gas with close to 8,000 hrs on it. It has a Westendorf TA-26 loader on it.Ours also only had single hydraulics on it so we use a joystick valve. The 2510 hydraulic pump was nothing great when compared to the 2520, 3020, and 4020. If you want to do a lot of work with the loader you may want to upgrade to one of these. Ours has a 4020 pump on it but i think its from an early 4020 the later ones had a higher output. We also replaced the wide front end with the heavier style used in the 4020 because we use the loader to stack 2,000 lb bales of hay.
marion arneson
11-06-2003 15:56:44
I am looking at a 2510 diesel wide front end. Manual transmission. Good condition. 1967 model. Guy is asking $3,000. How does this compare to gas with same stuff.
Is there value here?
Help
Glen in TX
11-07-2003 14:37:59
 Re: Re: 2510 Questions in reply to marion arneson, 11-06-2003 15:56:44
Here is some info for comparisons:
2510 Specs. Mfg. 1966-68
Gasoline engine 180.4 Cubic Inch Displacement
Diesel engine 202.6 CID
1965 Nebraska Tests
#916 2510 Syncro-Range,diesel, 54.96 HP,max.pto
#915 2510 Power Shift, diesel, 50.66 HP, " "
#914 2510 Syncro-Range, gas, 53,74 HP, " "
#913 2510 Power Shift, gas, 49.57 HP, " "
2520 Specs. Mfg. 1969-73
Gasoline engine 203 CID
Diesel engine 219 CID
1968 &69 tests
#992 2520 Syncro-Range,diesel, 61.29 HP
#993 2520 Power Shift, diesel, 56.28 HP
#1002 2520 Power Shift, gas, 56.98 HP
#1003 2520 Syncro-Range, gas, 60.16 HP
You can put a 2520 engine kit in when overhauling sometime for a boost and can also add the high output hydraulic pump. Value? Depends on condition and accessories? $2800-$8000
Ray
11-06-2003 12:33:17
That'about the going price for gas,Nf,2510's.
I saw one sell last week with 2800 original
hours for $3500.I saw a diesel with wide front
bring $5500.A couple weeks ago there was a nice
one in the photo adds for $4500.
Deere D clutch Question
11-06-2003 10:17:34
MY 1948 D seems to be stuck in gear but the engine turns over and the rearend won't move.Do you think it has to do with the clutch?
Glen in TX
11-06-2003 10:09:59
Sounds like you got a good deal. We have a 2510 diesel and wouldn't part with it. On the syncrorange you can shift by slowing and just clutching between 1-3, 2-5, 4-7, & 6-8. Stop to go in reverse or other ranges though. I don't know about the gas but our diesel handles a 6' JD, 540rpm shredder fine in big weeds and would take on a 7' too. We have also pulled a drag type 14' 540rpm shredder behind it too in light conditions only & 6 row cultivators. Don't have a loader on ours but have seen 3010s & 4020s with single hydraulics tapped and plumbed on the right hand main oil line for a single joy stick on a loader. You can put a later higher output pump on a 2510 for a loader too. Many 2520 parts fit it and when JD dealer overhauled our diesel they updated it to the 2520 engine parts and it runs better. Enjoy it.
T213R
11-06-2003 06:57:38
1. You got a great deal. The 2510 is a great tractor! The biggest problem with a 2510 is finding one. Not all that many were built and their owners seem to like them to the point of being unwilling to sell them.
2. Prices for 2510 gas tractors in my area are usually a bit more than you paid, so I would say you got a great deal!
3. It ought to handle a 6 foot just fine.
4. Not real sure about a loader, but it has the same frame as a 3020, so anything that will fit a 3020 should fit a 2510. My guess would be a 147 or 148 or a 48 loader.
5. John Deere Dealers can order one for you, and unlike most other brands that age, it will be published by JOHN DEERE. I'd look into getting the Parts catalog and the Service manual also. If you do a search, there is also an 1-800 telephone number, direct to John Deere Publications which will allow you to order one direct.
Does your tractor have:
-dual hydraulics?
-Powershift or syncrorange transmission?
Dual hydraulics would enhance loader operation,and so would a wide front end.
Newby
11-06-2003 08:23:44
 Re: Re: 2510 Questions in reply to T213R, 11-06-2003 06:57:38
third party image
I will plead ignorance on the transmission question. The shift arrangement is on the right side of the dash. A single shifter seems to select range and direction.
I put a picture of it here, perhaps you could tell me what it is.
As to dual hydraulics,I am not sure of that either. How would I tell?
There is one pair of Hydraulic couplers on the back.
Fred G
11-06-2003 08:34:00
 Re: Re: Re: 2510 Questions in reply to Newby, 11-06-2003 08:23:44
You have the synchro-range trans with 8 forward and 2 reverse gears. Very durable unit.
If you have one set of outlets you have single hydraulics. I'm sure those with loaders and hyd. knowledge can give some guidance on how to plumb in a loader.
Newby
11-06-2003 08:53:00
 Re: Re: Re: Re: 2510 Questions in reply to Fred G, 11-06-2003 08:34:00
Thanks Guys
Fred G
11-06-2003 05:36:32
I grew up with a 2520 so I have a few comments:
- Yes they are a great tractor for general farm work
- Well built and very dependable
- If the tractor is in good shape I don't think you paid too much
- We used both a 5' and 7' rotary mower on ours and the 5' was never a challenge. The 7' was a little too heavy (light front end) but the power was OK unless you got in heavy stuff. I would think a 6' would be a good all-around match.
- Don't know about loaders, we didn't have one, but there are many experts here. Ditto on the owner's manual.
- You mentioned the trans being different - is it a power shift or synchro-range?
