Powertrol
ken w
04-04-2000 15:08:04
What would cause a loud vibration under your feet, (just in front of the seat) when you operate the powertrol? Pretty loud doesn't sound normal. Would appreciate any ideas. Seems to do it more when raising under load. ken
Rob
04-04-2000 18:10:42
 Re: powertrol in reply to ken w, 04-04-2000 15:08:04
It would depend on what year and model you have. On the numbered series, the pressure line from the "live" hydraulic pump runs under the platform and is held down with a clamp right under the plate. On my 50 the bolt was missing on this clamp. On late lettered series, a pump whine or chatter could be transfered to the platform or seat box. Of course, this would be worse under load as the pressures increase and the pump works harder.
ken w
04-04-2000 20:12:09
 Re: Re: powertrol in reply to Rob, 04-04-2000 18:10:42
Thanks Rob its a 50 so all check that clamp first.
ToddT
04-05-2000 04:44:45
 Re: Re: Re: powertrol in reply to ken w, 04-04-2000 20:12:09
Your hydraulic cylinder is also directly under your feet, between the bull gears. There may be something going on with the piston and cylinder.
