4020
allen
11-05-2003 16:07:37
is a 4020 (gas) with a single front wheel worth buying, it is a early model
G-MAN
11-05-2003 16:21:09
 Re: 4020 in reply to allen, 11-05-2003 16:07:37
As an investment or as a working tractor? A 4020 gas-burner is going to be a lot harder on fuel than a diesel, particularly if used hard, although they're cheaper to purchase initially, and gas engines are also generally less costly to repair in the event of a breakdown - no very-pricey injection pump and nozzles to repair or replace, etc. The single-front isn't ideal for a lot of work, particularly for use with a loader, but it's also not commonly seen on a 4020. If the single-front is factory, you could be looking at a fairly rare and desirable tractor there, and it could be well worth whatever the guy wants for it, depending on how much that is. It just comes down to what you want it for.
old
11-05-2003 16:13:55
I'd say it depends on how much, what you plan to do with it etc. If its for a good price I'd say yes, for around $800 you can change it to a wide front end. Hope this helps some
