4020 Transmission noise
Bryon S
11-05-2003 15:46:11
I have a 1963 4020 with a power shift, sometimes when I shift to reverse and move about 10 feet, their is a loud snap in the transmission. The PTO has started to howl under load and the hydraulics chatter when the transmission is warmed up. I don't think the problems are related.
G-MAN
11-05-2003 16:27:00
 Re: 4020 Transmission noise in reply to Bryon S, 11-05-2003 15:46:11
The problems could very easily be related. The PTO clutch in a powershift tractor is located in the same assembly as the transmission clutch packs. The snapping noise and howling noise could be emanating from that area of the transmission. There could also be some internal oil leakage from that same area causing the hydraulic oil to become aerated, which can lead to pump cavitation and chattering. Further, the transmission pump, which supplies transmission operating pressure and charges the main hydraulic pump, is ALSO located in that same assembly. I'd say that you probably definitely have some issues there, how severe they are won't be easy to determine without going inside, and I would not run it until they're fixed, as further operation could lead to further damage and much more expense. Depending on what's wrong, it could be a fairly high-dollar job to get your tractor back in to shape. Loud noises from the powertrain generally aren't cheap.
MK to G-MAN UPDATE
11-05-2003 17:30:41
 Re: Re: 4020 Transmission noise in reply to G-MAN, 11-05-2003 16:27:00
I posted a question about my 4020 leaking oil between the bottom rear of the block and the trans housing in july after my local dealer said I needed a new powershift. You (G-MAN) said it is probably a seal gone behind the dampener. UPDATE: Took it to another dealer and they agreed with you before opening it up. After splitting it this was indeed the problem...great! much cheaper than a new ps. Replaced the seal and put a new dampener assembly in as the old one was soaked in oil. Brought it home, used it for 2hrs and same thing except instead of drip drip it now was almost running out. Dealer picked it up, took it back to the shop and split it again. They thought mabe they didn't get the seal in right. Looked everything over real good and found a shaft (not sure exactly where it was from) a foot long and about an inch in diamater that was worn a little. They replaced it in case it was causing the seal to go. Brought it home, used it less than 2hrs...same thing again!! They split it a third time and had every mechanic in the shop look at it to try and figure this out. Finally one guy discovered the secondary pump had a sticky valve. When it stuck it would pressure up to the point of blowing the seal. Put a new pump in and 25hrs latter it's still working good. This cost me $5000 ouch!! MK
david val
11-06-2003 00:09:28
 Re: Re: Re: 4020 Transmission noise in reply to MK to G-MAN UPDATE, 11-05-2003 17:30:41
are you sure it's a john deere? 'secondary pump' is not a term i know in a 4020. if you mean the transmission pump, then the valve that sets the pump's pressure is in a a valve housing outside the transmission (under the inching pedal) so why was the pump replaced?
there are two sources for oil leak in this area, engine oil (through rear engine oil seal or seal housing) and transmission oil through clutch pack input shaft seal, pump body seal or gaskets.
a high pressure due to stuck valve may brake a gasket or a thin castig, but if the pump, which is actually a gear pump, can create such a high pressure,it's probably in good condition...
david
MK to david val
11-06-2003 00:29:49
 Re: Re: Re: Re: 4020 Transmission noise in reply to david val, 11-06-2003 00:09:28
I'm not a mechanic or a trany expert. This is the info the service manager told me. He talked of a pump with a sticky valve which I'm sure he called secondary. He could tell me any story he wanted and I wouldn't know the difference, that's why I'm paying them to do it. If I could start my life over at 18, I would take mechanics, ag college, accounting, carpentry, journeyman welding, etc and then go farming...but then I'd probably be too smart to farm.lol
MK
11-06-2003 00:44:02
 Re: Re: Re: Re: Re: 4020 Transmission noise in reply to MK to david val, 11-06-2003 00:29:49
I'm going to find my work order sheet and post tommorow what it says they did.
Bryon S
11-06-2003 15:59:14
 Re: Re: Re: Re: Re: Re: 4020 Transmission noise in reply to MK, 11-06-2003 00:44:02
Thanks for all the sugestions, I'm going to have to have somebody pull it apart. This will be the first time that I will have to put any money in this tractor since my Grandfather bought it new. It is our primary tractor on our 250 acre farm.
