redution gear swap 47 A
Jim
11-05-2003 14:53:45
I have a 47A that is in for winter repairs,I sent the cam to roberts to have a competition grind done to it----as i was looking at the reduction gears----I was wondering if there was an easy swap to be had----at this time first gear is quite fast and it runs out of motor in 6500----Whats interchangable??? Thanks Jim.
Luke
11-05-2003 16:13:48
 Re: redution gear swap 47 A in reply to Jim , 11-05-2003 14:53:45
Jim, I have a 41' A that I have put a 52' model A reduction gear in. When you do this, you also have to swap gears on the belt pully so they match up. If I was you, I would change both the pulley and the reduction gear b/c you then get a better clutch system and you also don't have to worry about pressing the gear off of the clutch pulley. Email me if you have other questions. Luke
