Old drill
milo row width?
Big T
03-30-2000 13:04:04
Just got an old drill from a neighbor and am going to plant some milo in my lower fields this year, just south of St. Louis. There is about 7 inchs between the drop tubes, but it came with some inserts to maker wider rows. What row widths work best for milo yields in your experience? Thanks! Any thoughts on sunflowers appreciated also; I have never tried them either.
DougS
03-30-2000 14:11:05
 Re: Old drill - milo row width? in reply to Big T, 03-30-2000 13:04:04
I used the 14" spacing. That is plug ever other hole. It always looked good in the field, yielded some nice heads, but I could not tell you if it was worth combining. It was either grazed, or cut for silage. Doug in Tx
Haybaler
03-31-2000 06:07:20
 Re: Re: Old drill - milo row width? in reply to DougS, 03-30-2000 14:11:05
Will work on 7 but 14 may be better, I use 10. May be hard to get down to recommended lb/A (@8 lb/A) Ok if you go heavier. I going around 12-15 lb/A, don't like the 8 lb/A. At first will look like there isn't enough out there but be patient it will come. Starter fert. will help also. Good luck. HB
