Late A air pump
Kemper
03-28-2000 18:01:52
I'm getting some smoke around the clutch pulley, and i'm sure the rings are good, I took the line off of the air pump and i can't feel any air at all, Is the pump supposed to pump air into the crankcase or out? I did have it apart one time and put in new bearing on fan end. Maybe i didn't do something right.Please help!!
mark
03-29-2000 06:25:01
 Re: Late A air pump in reply to Kemper, 03-28-2000 18:01:52
The ventilator pump should pump out of the crankcase. Could be a broken spring on the pump vanes. But more likely the rings are stuck and you are getting blow by that way. Try working the tractor with a load on it and see if it gets better.
Ron B.
03-29-2000 08:40:25
 Re: Re: Late A air pump in reply to mark, 03-29-2000 06:25:01
The ventilator pump pumps air from a tube connected to the air cleaner into the crankcase and forces it out a tube connected to the rocker cover to the elbow on the intake side of the carb where it becomes part of the combustion mixture.
