John Deere Gator
ZAN E
03-27-2000 09:36:37
I am working on a John Deere Gator farm hauler. It will run for a few minutes and then quit firing. It has a kawasaki ingine on it. It has something that looks like a diaode or something. It is on top of the engine crankcase and has one wire going to it. The kill wire for the ignition is also T'ed into it.I suspect that it may be the problem. Any body ever had any experiance with these things and the ignition???
Please Emai me if you know somthing about the ignition on the Kayasike engine. I don't get on the John Deere board often.
Thanks,ZANE
Doug Littlejohn Squaw Val
09-21-2003 16:53:34
 Re: John Deere Gator in reply to ZAN E, 03-27-2000 09:36:37
Zane - Did you ever get this resolved? I have a 626 that just started something similar.
Thanks,
Doug
lrn
03-27-2000 14:04:22
I have a Gator 4x2 and as soon as it got warm it would quit. There is a little match book sized condensor (i'm not sure what it's called) with one wire on it. Anyway I replace it and that did the trick. I guess it's a common problem with this engine. Hope that helps.
