Electrolysis and Rust Removal
720Deere
11-05-2003 08:46:33
I have not tried Frank's electrolysis yet, but I know it works well if done properly. I have been using vinegar for small rusted parts. Has anybody else tried this? It seems to work very well for rust and paint removal. Once soaked in vinegar for a day or two, the rust disperses and you are left with either a clean part or a little "black rust" that easily brushes off.
I was just curious if anyone else ever used this. By the way, has someone kidnapped F-I-T and taken his place on the board? I ask this because alot of recent F-I-T posts don't end with the usual tractor models and web site link. Maybe Frank is Mr. Thinker!
F-I-T
11-05-2003 08:58:16
 Re: Electrolysis and Rust Removal in reply to 720Deere, 11-05-2003 08:46:33
720Deere:
I just get lazy! I'm not smart enough to figure out how to include the website stuff in my signature, so I have to copy/paste/move it around.
On the vinegar, I've never tried that. Vinegar is, of course, Acetic Acid, which is a pretty weak acid, chemically speaking, so it won't hurt any. It's probably on a par with etching ability with Phosphoric Acid. The benefit you get with Phosphoric is that you get a rust-inhibitive phosphate coating. With Acetic, you really should rinse it with a baking soda wash to neutralize any acid remaining, because the dry acid salts could draw moisture from the air later on and possibly pop your paint, but that's probably not a real big worry.
BTW, my wife says I'm "Mr. Stinker".
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
720Deere
11-05-2003 09:36:33
 Re: Re: Electrolysis and Rust Removal in reply to F-I-T, 11-05-2003 08:58:16
Frank's back!!! You're dead-on about the washing part. You also have to paint or prime asap as the rust process seems to begin immediately.
f-I-T
11-05-2003 11:34:31
 Re: Re: Re: Electrolysis and Rust Removal in reply to 720Deere, 11-05-2003 09:36:33
That fresh iron really gets red really quick! That's another benefit to using Phosphoric Acid. The phosphate coating really retards red rust formation. I still prime/paint or oil as soon as it is dry.
Frank
Mike in Louisiana
11-05-2003 13:07:52
 Re: Re: Re: Re: Electrolysis and Rust Removal in reply to f-I-T, 11-05-2003 11:34:31
Frank I just got my vat going about 1pm today. When I take the part out using (red devil), do i need to do anything other than rinse good under fresh water and wire brush
F-I-T
11-05-2003 13:35:17
 Re: Re: Re: Re: Re: Electrolysis and Rust Removal in reply to Mike in Louisiana, 11-05-2003 13:07:52
Mike:
Aha!! Another convert to the Dark Side!!!!! Soon my work here will be done !!!! (evil laugh)
Just rinse it under a hose stream, wirebrush if you want to remove the majority of the black oxide (you do not have to remove that, but I do...it looks nicer). Or scrub with a plastic scrubbing pad or some Scotch-Brite (I like the brown pad).
A powerwasher really does a slick job. Knocks off any loose paint, black oxide, various ashes of dirt, etc. As soon as it's dry, either prime it, oil it, or treat it with some Phosphoric Acid, so it won't rust. It will be so clean, the moisture in the air will get it rusting again.
Captain Coulomb
F-I-T's evil twin.....
Van
11-06-2003 05:12:03
 Re: Re: Re: Re: Re: Re: Electrolysis and Rust Remo in reply to F-I-T, 11-05-2003 13:35:17
Frank,
thanks for all your help in the past with settng up my tank, works better than anything else Ive tried. "Another convert to the dark side" pretty soon Frank there will be a tank of some sorts in every tractor guys shop in America! Too bad you can't get royalties. You are the "expert", even if not 50 miles from home.
Van
