3010 balancer
Wi-Red
03-27-2000 05:12:22
Took the pan off last nite, not the balancer, crank is cracked. Anybody got a good used one?
McC
03-27-2000 22:40:20
 Re: 3010 balancer in reply to Wi-Red, 03-27-2000 05:12:22
I just got an aftermarket crank for a 3010 diesel for one of the guys in the shop. It was brand new and top quality. I think you can buy them for around $1200.00.
ronm
03-27-2000 08:03:15
Red-a 3010 uses the same crank as the early 3020, & they're almost nonexistent as good used ones. JD has them for a hellish price, or there is an aftermarket crank-Abilene Machine has them, & I think CT-Country General also. I literally searched the world for these twice a couple years ago, ended up using the aftermarket, which seems to be perfectly good. I guess you mean the crank is broken, & not just cracked since it it making a noise. HTH, Ron.
Jim
03-27-2000 11:07:53
 Re: Re: 3010 balancer in reply to ronm, 03-27-2000 08:03:15
I looked for a crankshaft for over two and half years before I found a used one.
When you go back together make shure you get the line bore checked on the block , and resize the bottom ends on the rods .
