430 Lawn Tractor pto problem
Clay
03-25-2000 11:23:01
Although I consider my self to be a fairly good mechanic, I am having a problem figuring out the pto on our 430. Is there aa electric clutch which engages it. The belt for the fan turns fine, but for some reason, the clutch assembly for the pto does not engage when the lever is actuated. Any help would be appreciated.
emschram
11-01-2003 10:12:32
 Re: Re: What are they teaching these new JD mechan in reply to John T, 11-01-2003 09:00:10
I know exactly what your saying. I loved to sit in the local truck stop and look at all the big rigs. Man there were sure some nice ones back then. You still see some of them around. That's one of the reasons I like to restore these old tractors. Cheers emschram
david val
03-25-2000 20:39:19
 Re: 430 Lawn Tractor pto problem in reply to Clay, 03-25-2000 11:23:01
there is a switch in the seat that senses operator presence, if this witch is OPEN the pto wouldn't work.
Nate
03-25-2000 15:32:31
I have a 420 L&G tractor and on mine I adjusted the front clutch it has to be 0.018 in. between the rotor and armature. Also with the tractor not running turn the key and flip the switch and note whether you here the click at the clutch.
Steve
03-27-2000 10:17:52
 Re: Re: 430 Lawn Tractor pto problem in reply to Nate, 03-25-2000 15:32:31
I've had a similar problem with the electric PTO clutches on my JD 322 and had to set the 0.018" gap in the clutch. Once you have determined that the problem is not electrical, then adjust the gap.
I also put some Loctite on the adjusting nuts so that they won't loosen due to vibration.
Clay
03-25-2000 11:25:01
Just wanted to let all replies know, my e-mail adress was entered incorrectly. Here is the proper adress, [email protected]. Thanks, Clay
steevereno
03-26-2000 18:31:04
 Re: Re: 430 Lawn Tractor pto problem in reply to Clay, 03-25-2000 11:25:01
It could be alot of things and its hard to tell when we can't see it. It could be the seat safety switch, the pto switch, open fuse, broken wire going to the clutch, bad clutch ground, bad clutch, both clutch belts broke or the tension idler pulley for the two belts could be loose. Hope this doesn't scare you, good luck.
