3010 diesel
Wi-Red
03-24-2000 19:21:21
My son bought a 3010 diesel today that needs alot of work. It runs, but, engine hammers. We were told it is the balancer. Can the engine balancer be removed after taking off the oil pan, without taking off the timing cover? Thanks for any help.
Wi-Red
McC
03-25-2000 20:11:41
 Re: 3010 diesel in reply to Wi-Red, 03-24-2000 19:21:21
One other thing to check is the coupler drive on the hydraulic pump. The ones on the 20 series could make a lot of noise when they went out. The 3010 has a little different set up. It's worth a look.
twopop
03-26-2000 16:56:33
 Re: Re: 3010 diesel in reply to McC, 03-25-2000 20:11:41
McC very good point if the bolts are loose on either end it can make ALOT OF NOISE
Jim C
03-25-2000 17:18:16
Have had bushing go out in both of my 3020's they do make lots of noise. Have a balance setting in my shop that bushing spun and messed up casting. You need a very good press to press apart. Good luck.
twopop
03-24-2000 19:30:48
Yes the balancer can be taken off,after removing oil pan, it is not near the timing gear cover. on replacement, the balancer has to be timed to the crankshaft.
Wi-Red
03-24-2000 19:44:02
 Re: Re: 3010 diesel in reply to twopop, 03-24-2000 19:30:48
Thanks twopop, what goes wrong with this balancer? Have you ever heard one run with a bad balancer? This hammers pretty bad.
Thanks again, Wi-Red
ronm
03-25-2000 06:30:27
 Re: Re: Re: 3010 diesel in reply to Wi-Red, 03-24-2000 19:44:02
I have heard a 3010 w/a bad balancer, and yes they sound BAD, don't run it that way for long or it will tear up the drive gear on the crankshaft. Like somebody said, it's more likely a rod brg., but you have to pull the balancer down to get a good look at the rods anyway.
Jim
03-24-2000 23:10:46
My bet is you have a rod bearing spun 10 times out of 10 thats what happens. My two cents.
twopop
03-24-2000 21:29:23
I really havent heard about a balancer going bad until tonight,but thats not to say it couldnt happen.the only thing i can think of would be that the bearings were to go bad,or someone had it off for some reason and put it back out of time.i would also think that it wouldnt make the engine hammer as much as it would make it shake.where does the hammering sound like its coming from?low or high on the engine? Jds.can be bad about breaking rings and have them work their way to the top of the piston and then tapping the head,it sounds like a loud tap high on the engine
