Clean Carbs..
JDBob
03-20-2000 11:48:33
I have to agree with DougS. I would suggest getting a carb. rebuilt kit from Roberts Carb. repair "(712) 262-5311". Unless you have experince rebuilding the DLTX series carbs. there are tricks to them. Roberts can provide you with the two sizes of drill bits and an instruction sheet to effectivley clean out all the passage ways. There is one very small passway in the bottom of the carb. stem that is easily overlooked, if this one isn't clean the tractor will not idle correctly.
One hint, when you start your rebuild use heat to get the brass drill plugs out of the carb. If you heat them they will come out with ease.
Robert's also has a video avialable for about $25 bucks that walks you through the whole process step by step. I bought it and found it to be a very good reference too.
Hope some of this help.
JDBob
JDBob
03-20-2000 11:50:27
 Re: Clean Carbs.. in reply to JDBob, 03-20-2000 11:48:33
OOPS, meant to post this to the Bob's questions about carbs. below.
Mark J.
03-20-2000 15:02:12
 Re: Re: Clean Carbs.. in reply to JDBob, 03-20-2000 11:50:27
Check Robert's Carb out on the internet at
www.robertscarbrepair.com.
msj
