730 Taper lock flywheel
Kemper
03-19-2000 19:02:03
I looked at another 730D today it has a taper lock flywheel,and i noticed the flywheel cover is shimed out about a half inch away from tractor is this normal?
buckeye al
03-20-2000 15:15:00
 Re: 730 Taper lock flywheel in reply to Kemper, 03-19-2000 19:02:03
A taper lock fit under my 70D's cover just fine! That was back in maybe 1986. Still there still working just fine. Wouldn't think the 730's would be much different unless they did not slide it far enough on the crank. How much does the crank move from right to left as you engage and disengage the clutch? Would have to look in the book for sure but .010 sticks in my mind as the target.
