Fred, yes, the hydraulics [what little there was] was "live" as the pump ran off the L/H end of the governor shaft. ~The "H" didn't have a 3 point [but I suppose one could be cobbled up] & didn't have a very high top speed [it only had a 3 speed trans]. It did have a foot operated throttle over-ride to boost engine RPM�s for transport though. ~Those little H's are a fun little tractor to play with, make a great little cultivating tractor. Make a good garden plowing tractor with their 1 bottom plow. They are also good on belt loads for smaller equipment. ~They�re not much of a snow plowing tractor, can't handle much of a front end loader. They are mainly made to pull a draw-bar load & not lift a load. Most were used for cultivating & small acreage farms. ~The "H" is usually a good starting tractor, gets good fuel economy, sounds slightly different than it's larger 2- cylinder cousins & doesn't have any outstanding major design flaws. ~The weak points are very poor brakes, not much power for larger tasks, weak front end if abused, no live PTO, governor wear if it was operated at low RPM's for most of it's life, a few oil leaks. But basically they were a pretty robust little tractor for their size. ~I wouldn't be without at least one in my collection. ~As for their value, that depends on the area of the country you live in. If there are a lot of H's in your area they are relatively cheap & if you live in an area of large acreage farms that didn't have a need for the little "H" the price will be higher. ~I don't comment on tractor worth or prices so maybe someone else will comment on that area.. [email protected]
