Differential lock on a 310B Backhoe
Rick B
03-18-2000 21:23:18
I have a 85 310B backhoe and the diff lock is stuck, i have sprayed the linkage with WD40 and put lots of pressure on it but it still won't move i just bought it at auction and don't no a lot about it, any body have a clue to the problem. thanks in advance ,Rick.
Steve
03-19-2000 12:59:14
 Re: Differential lock on a 310B Backhoe in reply to Rick B, 03-18-2000 21:23:18
Have you followed the linkage down to the axle housing on the left side of the machine? Un hook it there and see if that releases it. If it does the problem is in the linkage. If not, it's in the axle housing.
Rick B
03-19-2000 14:45:43
 Re: Re: Differential lock on a 310B Backhoe in reply to Steve, 03-19-2000 12:59:14
Thanks for the advice, I took the linkage loose but the arm still wont move, is there a bearing in the housing that could be lockedup, the machine sat for about 2yrs before i got it, could the shaft be rusted from lack of oil, if so how hard is it to take apart and free up, will i have to take the axle housing apart.
Rick B
03-20-2000 18:28:58
 Re: Re: Re: Differential lock on a 310B Backhoe in reply to Rick B, 03-19-2000 14:45:43
BINGO !!!! I got it free, i soaked it in WD40 some more then i got a hammer and lightly tapped it down,then took a prybar and brought it back up,sprayed it somemore and repeated all of this about 50 times, it works good as new now !!
Jeff
10-21-2000 19:41:38
 Re: Re: Re: Re: Differential lock on a 310B Backhoe in reply to Rick B, 03-20-2000 18:28:58
I also have a 310 a with a differential lock that will not engage , have been afaid to force it.Any good suggestions any one. Thanks Jeff
