Engine rebuild questions on my 730 Diesel
will
11-04-2003 21:48:22
I have a 730 Diesel that is in need of a rebuild. It blue smokes quite a bit, and if lightly driven will drip a little oil from the stack. I had to replace the head gasket last fall. It appeared to have factory bore with a large amount of pitting and I think it is past honing. I believe a good .045 bore and new aluminum pistons would fix me up, but the delimma is, do I bother the crank or not?? Do I take the chance of removing the Flywheel and it being loose from now on?? If I dont remove the crank, but bore do I use the old bearings or get new ones to use on the untouched crank?? I dont really know how much oil pressure I have, as the guage is broken so I cant anwser whether or not my present bearing are worn or not. I do use this tractor for some heavy use, but not very often. I pull a 14' JD #210 disc, but I may only run 3 tanks of fuel through it in a year. Tell me what you all think, and I would love to hear any personal experiences. Thanks so much for all help.
Mike M
11-05-2003 07:38:37
 Re: Engine rebuild questions on my 730 Diesel in reply to will, 11-04-2003 21:48:22
Make sure you get the service manual from John Deere 720 manual is probably all you can get. In this manual they give you specs. for new parts and also a spec. for serviceable.Measure your crank bearing play and let this be your guide
also measure cyl. out of round and taper. If you don't have the extra dollars to make it to the new limits the service limits should be a good guide. Set it by the book and you should be fine.
upperpinecreek
11-05-2003 07:23:52
looks like you got some good advice on cost, i have a 70D for pulling that was redone for pulling by an aquantance of mine who has 10 pulling tractor, decided he had too many and i know he stopped counting at $10,000, i'm sure he had closer to 15,000 before it was done with parts and labor.
Gpower
11-05-2003 07:19:48
New 730 Pistons from Deere, 2 years ago I bought for 210 each. Ring set was 90, pins were 65. Bearings cost 85 and 73 for the mains, and 44 each for the rods. Gasket set for engine was 111. To have the pumps and injectors rebuilt as 350...pretty much they just checked them and put on new tips...not much done to them for the price I paid...I do my own now. Head job, new valves, re ground seats and magna-fluxed cost 175, boring the block was 250. Crankshaft was polished and checked for 50, did not need grinding. I did all the labor, still running good. Thats a ball park, I always add 20-30% over what I think the parts cost will and usually am ok. Hope this helps. Gpower
buickanddeere
11-05-2003 06:28:30
A quick cheap check for slobbering is to pull the injectors and reconnect back to the origional lines but spraying into the great out doors. Don't get close or you will loose flesh from the cutting action of the fuel stream. Anything other than a perfect pattern is not acceptable. Check past posts from Clooney for more info. You may get lucky and just need fresh injector tips,needles and springs shimmed to 2200psi. If the engine get cold ( below 180F) and lightly loaded even a fresh rebuild will slobber. When the head was off where the valve guides replaced, spring pressure checked and new valves if worn. A diesel won't draw oil down a guide like a gasoline engine but if grossly worn they could contribute to slobbering. Is there anything about the tractor that would contribute to it's value such as rare options?
Clooney
11-05-2003 03:54:22
Will, you are going to have quite a bit of money into larger pistons, rings, gaskets & cylinder boring, not to mention any cylinder head work you might need.. You might even have a problem finding someone in your area to bore the block for you as it takes a long stroke mill to get down those long bores. [Those blocks don�t ship cheaply]
~With that in mind you really don't want to spend all that money without at least looking at the engine bearings & crankshaft at initial teardown.
~A full engine overhaul will be quite expensive but is better than spending big bucks on a cylinder re-bore just to have the crank or bearings go out soon there after.
~You also should check out the L/H cam drive gear train as that is a high wear area on those diesels. The late 720D & 730D had a much improved cam gear drive set-up but it still was a problem area.
~One thing you mentioned kind of sends up a red flag,,, that is that cylinder pitting,,, that usually means water was in there & in most cases the water will also find it�s way into the crankcase & onto the crankshaft & bearings.
~Another thing to be somewhat concerned about is the center main bearing... Those are a real pain to work on [replace] so in a lot of cases weren�t replaced at an earlier overhaul. It that is the original center main bearing you are probably on borrowed time there.
~Opening that engine up is like opening �Pandora�s Box� once open it is hard to close if you find problems in there & one thing can lead to another so you could find you end up with a pile of money in that engine [it can really run big bucks in a hurry if the crank needs work] .
~If you only use that tractor occasionally you might want to just check the crank bearings, cam drive, & hone the cylinders, then re-ring it. It probably won�t last for long hours of use but you might be surprised on what a re-ring of your existing cylinders can do for light use operation.
~If you do decide to go through that engine keep us posted of what you find while in there. Those big diesels make a good conversation thread & can lead to a long term project�
~I haven�t been completely through a 2-cyl diesel in about 10 years so maybe Frank [F-I-T] can give you up to date prices & expectations as he is probably still recovering form the financial debt of going through his 70D�..
[email protected]
Bo in Maryland
11-05-2003 06:22:29
 Re: Re: Engine rebuild questions on my 730 Diesel in reply to Clooney , 11-05-2003 03:54:22
'Opening that engine up is like opening �Pandora�s Box�'
.....LOL!...that's one of the greatest statements I've ever read on this board..... this morning I'm going to see Bill, an old timer buddy of mine who's re-doing a 730 for the grandson of the origional owner....at the onset Bill says to the grandson "are you sure you wanna do this?" the grandson says "yep, I want that old tractor to look and run just like it did in Grandpa's day[famous last words]....here's a check for $10,000 to get the ball rolling"..... as of two weeks ago Bill had already burned thru the $10K , and that's just in parts and machine shop work....he hasn't figured labor yet.....
Good luck to everyone!
Bo
F-I-T
11-05-2003 06:08:57
Clooney:
Have you been talking to my wife?
I will tell you that you can put a nice set of all four tires on a '70'Diesel for less than a new set of .045" over pistons!
Frank
