Fabricated flywheel wrench
Valvejob
03-18-2000 20:44:26
I have been reading this discussion board for months and have seen many postings for torque specs and/or wrenches to access the flywheel bolts. After seeing a posting for a JD version for sale for 95.00 I decided to build my own. I very simply cut a 1 1/16" deep 12 pt socket and welded each end to a "C" shaped frame made of 5/8 X 1 1/4 low carbon steel. It worked better then I expected, not only was I able to use a torque wrench but I found there is room enough to use a 6 point socket if desired. (the 12 pt was very easy to engage the nut though) The flywheel on our B had worked its way out. Just for education I checked mine before loosening and they were at 60 ft.lbs., knowing that wasn't enough I brought them to 100 (1 1/2 grunts) after adjusting end play. If it moves again I'll brind them up to two grunts.( I rarely use a torque wrench other than for head bolts)The tool made this job easy. If anyone wants dimensions to make thier own let me know. I would also consider making some for sale if anyone is interested. Unlike the JD oil filters I just bought and found made in mexico on the package, These will be marked made in Maine USA
