How does he do this?
Loren from MN
11-04-2003 20:54:54
How does he do it? There is a 53 model 50 for sale in the photo ads, with what appears to be a JD 45W loader and three point hitch with back blade. How does he run all these devices at the same time on a 53 "50"? Does he have a second hydraulic pump?
DaveH 50
11-04-2003 22:03:10
 Re: How does he do this? in reply to Loren from MN, 11-04-2003 20:54:54
third party image
The picture is small and with only one view it's not clear how he's doing it.There are several possibilities.
1. He could be using an auxillary as you stated - running off of the pto or even belt driven off of the belt pulley. Deere also made a pump that fit in between the distributor and governor. Using one of these with a hydraulic fluid resevoir might work.
2. Selector valves could be in the Power Trol unit where the dummy plugs or couplings usually go. That allows you to plumb a set of remotes/hoses into the side of the Power Trol unit. The down side of that is that you can still only use either the remotes or the rockshaft - not both at the same time. You have to turn the selector valve to either one or the other.
3. A Baker Multi Valve could be sandwiched in between the Power Trol unit and the rockshaft housing. The Baker Valve is an after market valve that gives you a set of remotes with it's own lever while leaving the factory lever to control the rockshaft.
There could be other ways to do it, but these are the ones that I'm familiar with.
Dave
MK
11-04-2003 21:58:05
My dad had a 60 and then a 630 in which he plumbed into the hyd pump on the right side and ran a hose to an aux triple valve and a second hose ran back to the pump for the return. It didn't interupt the factory hyd lever beside the seat. With this setup he could operate a cyl on an implement and run the lift, tilt, and grapple cylinders on the loader. I would have to be standing looking at the setup again to explain it better but it worked good as long as you worked one lever at a time or else your flow was reduced.
