2010 three point lift problem
Believer45
11-04-2003 19:58:03
I just bought a 1961 2010RU and have a problem with the lift on the three point hitch. It will lift me, it does not drift down with me on the lower bars but it will not lift a bush hog. It does have the optional live hydraulics on the rear with control lever in the dash. Any ideas where I should start?
Thanks in advance for the help.
Dave / Believer45
John J. Otto
11-05-2003 08:34:05
 Re: 2010 three point lift problem in reply to Believer45, 11-04-2003 19:58:03
does your 2010 have split arm on the three pt there is a little lever under the seaton yourleft side check its position need to check your book for the correct setting hope this helps john otto
Believer45
11-05-2003 09:53:17
 Re: Re: 2010 three point lift problem in reply to John J. Otto, 11-05-2003 08:34:05
Lever on left side that shows positions for L - LR - R so I would assume it is split. It raises fine with my weight (270#) and does not drift under that light load. Thanks for the reply - I think it is probably either a lever set wrong, linkage out of adjustment or check valve somewhere not seating properly. I think I am going to remove the auxiliary hydraulics since I am not going to use them. I can reinstall if I need to later. This will eliminate the auxiliary circuit from the equation.
Thanks for your reply.
Dave / Believer45
