JD 70LP question
Jade
03-16-2000 09:22:07
I'm about to go take a look at a 70LP wide front, and wondered if anyone knew the horsepower on these things, ball park anyway since I don't have a serial number. Also, any advice on LP tractors? I've never had one, so not sure what to expect. Thanks for any info.
Alward
03-16-2000 12:01:49
 Re: JD 70LP question in reply to Jade, 03-16-2000 09:22:07
My Two Cylinder Magazine shows 51.97 H.P. at the belt pulley.7.3 to 1 compression ratio versus 6.16 for the gas model & 4.6 to 1 for the all fuel tractor.This comes from the January-February 2000 magazine.The gas model produced 50.35 H.P & the diesel produced 51.49.Al
twopop
03-16-2000 10:13:11
The 70 jd has about 50 pto horse power,my book doesnt list the lp seperate but i think jd put in different pistons in the lp to compensate for less power in the fuel than gasoline.personally i like the lp over gas,but then i use lp for both pumping water and household so i have a large nurse tank.the lp will start easier cold and should be less expensive to operate at least they are here,but our lp is usually around 62 cents a gal.
Haybaler
03-16-2000 11:31:06
 Re: Re: JD 70LP question in reply to twopop, 03-16-2000 10:13:11
The LP tractors run an lot cleaner too (ie not so much carbon in combustion chamber as gas or diesel). Pay close attention to the converter that runs into the carb. These can give trouble (blown seals and such).
STMTS
03-16-2000 20:52:27
 Re: Re: Re: JD 70LP question in reply to Haybaler, 03-16-2000 11:31:06
LOOK CLOSE at the flywheel they were REAL bad about working loose pop the little center cover out take a look for pieces of tin shims they indicate wear
Jade
03-18-2000 08:55:10
 Re: Re: Re: Re: JD 70LP question in reply to STMTS, 03-16-2000 20:52:27
Thanks everyone! 50 hp is perfect for what I was looking for, and I'll check out the things you mentioned as well. =)
