70d first gear
teamroper
11-04-2003 17:10:05
do all 70d have the same first gear
Clooney
11-05-2003 08:57:29
 Re: 70d first gear in reply to teamroper, 11-04-2003 17:10:05
Teamroper, I have held off on answering this question hoping someone that has seen an optional 1st gear set in a 70D would answer.
~To my knowledge there was only one 1st gear set for that 70D�. Yours is probably too fast for you correct?
~On the late 720D & 730D [& even the early 720D with the later shafts installed did have a 1st gear option but that was actually to get a different 5th gear.
~There were some direction reverser type gears available [not sure if for the 70D though] but those were more for cotton harvesting usage.
~Deere realized they had a problem with that high 1st gear & added a nice creeper 1st on the 720D..
~Don�t bet the farm on the above information as there were some oddball Deere & aftermarket parts available for the 70 series tractors but I haven�t ever found or seen a different 1st gear for the 70D�
720Deere
11-05-2003 09:44:10
 Re: Re: 70d first gear in reply to Clooney , 11-05-2003 08:57:29
Clooney,
Do you think that this 70 "racing" first gear thing came from people who thought that the 70 would have monsterous power compared to the other row-crops that Deere had built previously? Maybe they thought the 70 had so much power that first gear should be higher to produce more work.
Anyway, I could live with the high first gear alot better than high speed reverse. Whoever dreamed that one up never backed a wagon into the barn!
720Deere
11-05-2003 08:54:22
I posed a question a while back about the difference between the 70 gas and 70 diesel first reduction gearing. There are different part numbers for the two different models. I don't remember getting any replies. Maybe that one is unknown, but as far as different years of 70d having different gears, I don't believe that happened. The 720's had an optional gear ratio, but I have never heard of anything like that for a 70d.
buickanddeere
11-05-2003 18:11:58
 Re: Re: 70d first gear in reply to 720Deere, 11-05-2003 08:54:22
The 70's ancestor the "G" was also equiped with the way too fast 1st and "R" for "racing" while backing up? The stock "G" is pretty feeble compaired to a stock 70 gas or diesel yet was geared fast. The 60 was quick in reverse as well but at least had a creeper 1st. The 1st gear speed on the 70 required the man on the hay wagon to run from the baler to the back 4th & 5th rows on the hay wagon. Seem like a rest to pile the 2nd & third rows.
Buckeye al
11-07-2003 14:45:46
 Re: Re: Re: 70d first gear in reply to buickanddeere, 11-05-2003 18:11:58
Causes me to recall a story.... Seems my nephew & one of his buddies were working the wagon behind my 70D & the 24T. Heavy first cutting that had not been rained on. BEAUTIFUL and PLENTIFUL. First gear was putting out a bale every 11 strokes. They were getting mouthy & making fun of the old 70D. Babbling something about being noisy and obsolete. Going 'round the end I slid it into second for a single windrow. A bale every seven strokes is too hard on the baler (for my tastes) but the 70D didn't care a bit. The boys cared a lot! Never heard any more smart alec remarks. First gear proved just fine!
