John Deere 60
Leonard McCloun
03-14-2000 12:25:15
I have a JD 60 which I use as my main work tractor for 25 acres. Last fall when I was working it pulled itself out of 4th gear. I could then slide the shifter to neutral and then back into 4th and go again for a little while before it happened again. Any ideas and how much to fix
Haybaler
03-14-2000 14:27:15
 Re: John Deere 60 in reply to Leonard McClounie, 03-14-2000 12:25:15
Could be a bent shifting fork or the detents on the shifting fork shaft could be worn. I have had my 730 do the same thing and it was the fork, and while I was in that far I checked the end play on the gear shafts and removed some shims to tighten it up. Just take off the trans top plate and you'll see it right there. Make sure your in center neutral before removing the plate. Good luck. HB
ZANE
03-18-2000 06:05:34
 Re: Re: John Deere 60 in reply to Haybaler, 03-14-2000 14:27:15
A friend of mine has a John Deere 60 that is being parted out. He still has all the parts less some of the engine accessories and will sell the rest reasonably. Contact me by Email and I will give you his phone number if interested.
My Email is [email protected]
The tractor is located in Talladega County Alabama.
Haybaler
03-14-2000 16:49:25
Just had a brain cell start functioning again. I had my 60's trans go bad this summer with a bad shift fork and had a devil of a time finding one. Called the guy at Two Cylinder Plus and gave him my casting # for the fork. He then told me that 60's were originally bad about jumping out of gear and that they had been redesigned and a new shifting arrangement was put in. The new arrangement is identical in most parts to a 620. The part casting # I had was for a 620. JD sold a kit to retrofit made up of these parts for earlier tractors. Don't know if mine was a kitted tractor or a redesigned tractor. Might keep this in mind if yours has a bad fork. Good luck again. HB
STMTS
03-14-2000 18:58:55
 Re: Re: Re: John Deere 60 in reply to Haybaler, 03-14-2000 16:49:25
There is also two flat roller bearing(JD7904) on the counter shaft under the cluster gear that will wear flat spots on the rollers and can give the same effect as to much end play
Haybaler
03-15-2000 05:57:09
 Re: Re: Re: Re: John Deere 60 in reply to STMTS, 03-14-2000 18:58:55
These bearings are on the bottom shaft and you have to take out EVERYTHING to get to them. Mine were actually coming apart, a couple of rollers were missing (never did find them either) and had NO idea they were bad. I don't if this led to my fork problem or not, but kind of dought it.
Leonard McClounie
03-15-2000 06:07:00
 Re: Re: Re: Re: Re: John Deere 60 in reply to Haybaler, 03-15-2000 05:57:09
First of all THANKS!!! for all your great advice guys, I really appreciate it. I have another question, where can I find a shop manual on the JD 60. I would like one that really shows a step by step procedure to repairs. Thanks again
Charles
03-15-2000 10:04:21
 Re: Re: Re: Re: Re: Re: John Deere 60 in reply to Leonard McClounie, 03-15-2000 06:07:00
Call John Deere Publications, (800) 522-7448, and ask for a service manual and a parts catalog. They will tell you 2-3 weeks delivery time but it usually seems to be 1 week.
Leonard McClounie
03-15-2000 04:33:39
I have also been told that it could be worn gears as they used flat gears not tapered, could this also be the case?
STMTS
03-15-2000 18:57:07
 Re: Re: Re: Re: Re: John Deere 60 in reply to Leonard McClounie, 03-15-2000 04:33:39
They use straight gears alright but as long as all the bearings are tight the gears remain straight but too much end play causes to walk up and down at a angles this causes them to walk out of gear.And (they)are techaniclly right, If they were run loose a long time (jumping out of gear) they will wear.And if bad enough would need to be replaced.
