Valve cover gasket for JD B
AS
03-13-2000 11:27:24
I have a new cork gasket for my valve cover on a JD B. What is the proper way to install it so it won't leak? Do I soak it in oil? My manual says to shellac it. What does this mean?
Thank-you.
Gino
03-13-2000 17:10:34
 Re: valve cover gasket for JD B in reply to AS, 03-13-2000 11:27:24
I would permatex the gasket to the valve cover and then let it dry. When it has dried I would install the valve cover without using any permatex on the cylinder head side.
steve from mo - gasket shellac
03-13-2000 13:58:59
Gasket shellac is not like wood finishing shellac. It stays sticky. If you put gasket shellac on both sides of the gasket the gasket won't move when you install the valve cover. Of course when you need to remove that gasket, you will need a heavy duty scraper to take off the shellac and the cork that sticks to it. You can use grease or Permatex to keep the gasket in place or you can just be careful.
Chuck
03-13-2000 13:18:37
It will not leak without any sealant, however I use some sealer to hold in place.
