Jd 212 transmission
patrick albrigh
03-12-2000 16:26:08
my 1985 jd model 212 garden tactor has started to show it's age. the tractor only goes about the speed of second gear when in fourth, occasionally when in fourth it will run as it should. the motor is strong, belts appear to be tensioned properly, and the gear oil was changed. is my transmission shot? what could the problem be? any advise appreciated.
mark
03-12-2000 16:36:07
 Re: jd 212 transmission in reply to patrick albright, 03-12-2000 16:26:08
Your variable speed pulleys are bound up. Try squirting some some wd-40 up in your pulleys while the tractor is running. Could be rusted up from winter weather. If that doesn't work, the variable speed assy. may need to be removed and center sheave and bearing replaced. That center sheave needs to float smoothly on the bearing.
MrG:What gear oil did you use?
03-13-2000 08:06:04
 Re: Re: jd 212 transmission in reply to mark, 03-12-2000 16:36:07
A friend of mine that refurbs JD L&G told me not to use Hy-Tran in my JD317. He said use JD Hi-Guard or ATF Type-F.
