37B valve adjustment
Hal
11-04-2003 11:31:03
when i was disassembling my b i noticed that my valve adjustments were screwed out to the max position and they were still a bit loose question is do the little"adjusting cups" wear ? would i gain some length by replacing them or can i machine a small amout from the rocker arm rail?
if so how much should i start with thanks Hal
WTW
11-04-2003 14:27:45
 Re: 37B valve adjustment in reply to Hal, 11-04-2003 11:31:03
It does not take much adjustment to get the valve lash to tighten up. If you feel the lock nuts do not have enough thread to secure to, put the nut on the opposite side of the rocker arm. Someone may have a thicker than normal head gasket installed in it that could cause this type of situation. Good Luck, Dave W.
Ron
11-05-2003 16:49:01
 Re: Re: 37B valve adjustment in reply to WTW, 11-04-2003 14:27:45
sounds like rocker wear at the valves,
also check valve length for wear.
at times machine shops will trim the tops
of the valves due to the ends wearing at a angle due to rocker arm roll over.
if you need the valve specs let me know and
will look it up for you
