B fuel strainer leak
Larry
03-10-2000 07:31:07
My late styled B has a fuel strainer on the carb held on by a brass bolt. The strainer leaks where the bolt passes through the metal cap. There does not appear to be a gasket on the bolt nor do any carb diagrams I have show a gasket. How do I keep it from leaking fuel?
mark
03-10-2000 11:42:21
 Re: B fuel strainer leak in reply to Larry, 03-10-2000 07:31:07
Usually when they leak there they are cracked from being tightened too much. Clean it up and check for a crack.
Clyde Scott
03-12-2000 07:17:56
 Re: Re: B fuel strainer leak in reply to mark, 03-10-2000 11:42:21
I had the same problem and never did get it to stop leaking.. Finally had to purchase a new one.. They are still avaliable from John Deere Dealers..
Clyde Scott, Moultrie, GA.
