B oil lines
David S
03-09-2000 10:58:51
Does anyone know of a source for the brass solder fittings for the oil lines on a JD B? I think the copper tubing is 1/2 OD. JD tells me the complete oil lines are not available anymore. I've checked plumbing supply with no luck.
Dick Cumiskey
03-09-2000 13:09:18
 Re: B oil lines in reply to David S, 03-09-2000 10:58:51
David,
These fittings are available in all of the JD fuel line sizes from Stephen Equipment Company, Franktown, Colorado 303-688-3151
chuck
03-10-2000 04:41:43
 Re: Re: B oil lines in reply to Dick Cumiskey, 03-09-2000 13:09:18
I've gotten them from JD, also should be able to get used. On the small lines, I've made them, you can carefully drill the line out of the fitting and solder those back to new lines....
