End play on cam gear
Jack
03-09-2000 10:21:31
I was assembling my JD 70,and when I put the cam in,there is a little slack between the crank gear and the cam gear where they mesh together.Is this common or is this something to be concerned about.There is nothing binding and everything turns good.Thanks,Jack(TN).
clooney
03-09-2000 13:36:52
 Re: end play on cam gear in reply to Jack, 03-09-2000 10:21:31
Jack, there isn't much of a spec on the gear backlash,"BUT" I have done a couple of complete "70" gas overhauls & if there is very much gear lash between the cam & crank gear you will get a knocking noise at low RPM and heavy load. I doubt that the noise will bother anything unless you plan to put lots of hours on the tractor, but it is annoying. It isn't cheap but it is a lot easier to replace them now than later. Check to make sure the play is even all the way around, they tend to wear heavy in a couple of places. You will also probably find a lot of play between the cam & governor gears. If you put new main bearings in it they might have been bored off center, that will increase the play also. If you used the tractor under heavy pull before the tear down & didn't hear a knocking noise you will probably be OK to re-use the gears.
