44B steering shaft eccentric offset?
Valvejob
03-06-2000 20:50:12
Does anyone know the center to center dimension of the ID and OD for the steering shaft eccentric bushing? After finding out a new one will consume two Ben Franklins I would opt to make one. I have the bronze and equipment needed but would like to avoid the frustration of achieving this dimension through trial and error. The old one is to badly worn to be of any help. Also is it possible to change the packing by simply dropping the shaft a few inches? (the tractor is hybernating in my cellar for winter repairs and I don't have enough hieght to remove the shaft completely)
I have been reading this discussion board for several months now and have learned alot from everyones postings. Thank you!
