John Deere 1010 (Gas) Width
Steve Renner
03-06-2000 20:23:50
Am thinking of buying a JD 1010 gas tractor. The tractor needs to be as narrow as possible, like 60 inches or less across the outside of the rear wheels.
I saw one today at an auction. The inside of the rear wheels were set about 3 inches out from the final drive housing, and the dish of the rear wheels was facing out.
Does anyone know if the rear wheels can be sucked in on the axle so that they are pretty much flush with the final drive housing? Can the wheels be turned around so that the dish faces in toward the tractor? can you run narrow tires (like 9.5x 24) on the 1010? What is the narrowest possible configuration for the rear wheels? I figure you can get down to 58 inches, but does anyone know for sure?
Thanks for the help.
Steve
bob
03-07-2000 16:40:27
 Re: John Deere 1010 (Gas) Width in reply to Steve Renner, 03-06-2000 20:23:50
According to my operator's manual you can only get minimum width to 60" or below with the RS (singlw row crop) model. You can get it to 58 1/4" with power adjusted wheels or demountable rim wheels. The utility model can get to 60 1/4", but only with power adjusted wheels. You can put 9.5 X 24 tires on the utility or single row crop.
Steamer
03-07-2000 06:32:53
The dish of the wheels can be reversed. If this is a Standard version tractor, the rims can be set in one of four positions. That gives you eight possible wheel spacings. If the tractor is a Tricycle or row-crop utility varient, then adjusting the wheel spacing is easier. I surmise from the 24" tire size you're mentioning that the tractor is a standard version. You can get the wheels down to the 60" you require.
